83 115hp spark test?
Fiftybucks
In this forum, I noted that you should not turn over the engine without the spark plugs in the wire, and also grounded to the block as engines with type III ignitions can be damaged. I am not sure what happens as to exactly what might cause the damage, but I made a sheet metal holder for the plugs, and grounded that to the block with a ground wire.
the sheet metal holder seems to work, and all six are sparking nicely. here is a movie clip.
DSCN1876_zps20faeb60.mp4 Video by nomain | Photobucket
if they look good are they good, or do i need to measure or test something?
canoemang
Re: 83 115hp spark test?
You can leave the plugs all in and use a spark tester that you can change the gap or space of the arc... Remove one at a time and test individually.
Thats a cool video..
Fiftybucks
Working on the hard starting issue now. I will post to another thread. Thanks..
