Rkrough
- Dec 1, 2011
- 47
I had a deal with my wife that I could build a wood boat if I built her a new house first. I built the house and then not long afterward my wife showed me a picture of a skiff on an Ebay charity auction, knowing that I'm a sucker for commercial boats in general and Downeast style in particular, she knew I would be in love with it. A couple days and $610 later I brought it home last October.
The boat had been used for inshore lobstering and fishing since new so everything was pretty worn out, The 70hp motor had 60lbs of compression (later found the block cracked around #1 cyclinder liner) The deck was soft and the bilge was wet
As bad as it looks the stringers were not rotted except for a 2' long section of the top 3" of the keel stringer
I built a shelter over her and stripped her down to the stringers I ran a fan 24/7 for the next two months getting her dried out
Once dried I used a sandblaster with Black Beauty media at 90psi to clean up her bilge and give some tooth to bond new fiberglass. The rotted section of stringer was where I planned to install a 27 gallon fuel tank. I header-ed the keel stringer on each end of the tank. I added 3 layers of 1708 under the tank to keep the bottom stiff and then added a layer of 1708 between the stringers and over the stringers for the rest of the hull. I put in new PT doug fir floors.
I foamed filled the bilge with 2 part urethane (9 gallons) topped with 1/2 MDO
I'll post the rest this evening
