82 merc 50 starts but will not shut off
szczepanik
i have a 82 merc 50. i wired it to the key switch. i can start the motor but it will not turn off with the key. can anyone give me some ideas on what i did wrong with the wiring.
CaptainHook
Re: 82 merc 50 starts but will not shut off
Do you have all necessary wires connected? You need to send voltage to the motor which your doing but some ignition switches need to be grounded to "short" the ignition system to stop spark.
mike1245
on your switch there should be 2 pins labled m one comes from switchbox and other is a ground thats what shuts it off is grounding out switchbox
szczepanik
i will check the wiring again. thanks for the posts.
