82 Johnson running rough!
rscholar
My 1982 Johnson 25 HP Model # J25TELCNB outboard is running rough. Took off, and totally cleaned carb., replaced almost all wiring, sprayed carb. cleaner in cylinders, plenty of spark. It starts okay, seems to idle fine, then starts sputtering, and dies, but will restart. It smokes up a storm, and can't seem to get the Lean/Rich right. I think it is running very rich, but the needle valve doesn't seem to cooperate. Fuel pump is working okay. Lots of dirty/oily water in water bucket. I was dumb, and used about 1.5 gallons of last years gas/oil mixture, but added 4 new gallons to it. Do you guys think my needle valve is bad? Was wondering, if getting it on the water and running it for awhile in gear will help? Getting frustrated, and fishing is almost here!!! :confused:
jasper60103
Re: 82 Johnson running rough!
Well, I would start off with fresh gas. Also, if you tested good compression and spark, I would assume the carb is your problem, esp if the ss needle adjustment doesn't make a difference.
I'm having a similar problem with my '81 25hp. Last Fall I bought a carb kit and gave the carb a good 24hr soak and cleaned the passages. I haven't had a chance to test it yet due to winter, but I'm hopeful that does the trick. Good luck.
RCwaterski
Hi,
Did you figure this out? I have exactly the same problem. I think it is the fuel pump, I pulled it off and the pulse hole has gas leaking out into the engine, this explains the gas/oil in the water bucket but not sure it will make it run rough. What did you figure out?
