Just bought my first pontoon yesterday. Motor turns over fast and strong but will not fire off. Plugs are getting white fire and fuel is getting to the plug, b/c the plugs come out wet. Any and all suggestions are welcome please. Thank you.
Carson W,
Make sure you pump the fuel primer bulb up until hard, left the warm up lever to full up, turn key but don't start and push in for about4 seconds then turn the key to start and it should fire off for you. Once it starts bring the warm up lever back toward the starting position so the motor does not over rev on you once it does start and let it warm up at around 1100 to 1200 RPMS for about 2 to 4 minutes then back away from the trailer and you should be good to go.
