:welcome: Paulino70 to iboats. Great having you aboard...
Okay there are a few things that can cause your problem. Obviously you have a meter and can use it as well. And that will help locate your problem. On your engine there is a neutral safety switch. What that switch does is makes sure you can't start the engine unless it is in neutral and not forward or reverse. So if that switch is not working or out of position, that could keep your engine from even trying to start. That switch is usually connected in line with the starter solenoid. So even with voltage at the starter solenoid, if the neutral safety switch in not closed to provide a ground, it will not crank. So take your meter and touch the small terminal on the starter solenoid and move the shifter from forward to neutral and see if you can read ground when in neutral. You don't even have to use the key or try to start the engine for that test. If you do read ground, then that switch is good. That means you may have a bad starter solenoid. You can test that by jumping from the positive battery terminal to the starter to see if it will spin. If it does, then you have a bad starter solenoid. Post your results back on here... :thumb:
