Having problems getting my engine to idle fast enough. Throttle cable was adjusted to keep engine running. If I attempt to run with cable disconnected it will die. SELOC manual does not explain the function of the screw in the red box (in the image). Even if I adjust this full cw it does not open the throttle plates at all. I have left it as is.<br />
<br /><br />There are no adjustments on the carbs per the manual. All have fixed jets, I believe.<br /><br />I am missing something here and any help is appreciated.<br /><br />Thanks,<br />Greg
