81 Mercruiser 165 6 cyl
clb077
I have an 81 Mercruiser 165 6 cyl. When I turn the key to start it starts but when I let the key to run it shuts off. I replaced the ignition switch and it does the same thing. I also replaced the ignition coil, points, condensor, fuel pump. It is getting fuel, the spark plugs are firing. I can not figure it out. Please help
cr2k
Re: 81 Mercruiser 165 6 cyl
You have a bad circut in the IGNITION circut. With the key ON do you get any voltage at the + side of the coil? Could be the resistance wire if you have one (would be a dark brown wire from the + side of the coil). Follow that back until you have power and splice in a new one. Don't run without the resistance wire (if so equipped) it will burn up your coil and leave you stranded.
clb077
So to do this, I need a voltage meter? As you can tell I do not know much about electrical.
Ayuh,.... Welcome Aboard,... A simple Test Light will work for what ya need to do,...
clb077
Is there a ignition sensor on this motor?
achris
More fish than mountain goat
What on earth is an 'ignition sensor'????... If you mean 'knock sensor', then no...
Sounds very much like you need a 'resistance wire' kit. All the instruction for fitting it are in the kit. OEM part number is 84-94227A2
Chris.....
Maclin
clb,
This may help you understand why it could start and run with key in the START position but die immediately when the key returns to ON after starting...
Power to the coil is limited by a ballast resistor when the igniton is ON. This ballast is needed for differing reasons, but IS needed for most ignition coils and your engine has this type of ignition. So, with just the key in ON there will be about 9 volts to the coil, this is absolutely normal and as designed. If there is no voltage in this condition then there could be a problem with the ballast resistance component or wiring/connections.
When the key is in the START/CRANK position this ballast is bypassed to give some extra spark just during cranking.
So if there is a problem with the ballast resistance component or the wiring in that circuit then the coil can only fire when the key is in the START/CRANK. Engine starts :) , key goes back to ON and the coil loses power, engine dies :( .
clb077
Ok so I bought a continuity tester and checked the positive side of the ignition coil and it lit up. Does this mean it is getting 12 volts?
Don S
Did you buy a continuity tester or a 12volt test light? Big difference.
clb077
I bought a continuity tester.Where canI buy a test light at? Auto parts store?
clb077
Sorry guys, I am new to this. Lol
Don S
Any hardware store, walmart, autoparts store, etc.
They have a 12 V bulb in them and a ground wire and the light lights up when you have power turned on and the ground wire is hooked to ground.
A continuity tester has a battery in it and powers a wire to see if there is continuity (no breaks in the wire)
Don S
CLICK HERE
clb077
Ok, so I tested the plus side of ignition coil, light did not come on. I tested all 4 termanals on the back off the ignition switch all lit up except the c termanal. Dose this mean that is the bad wire? Thanks for all your help guys.
Don S
If your test light is hooked up like the picture below, then either the kill switch is bad, or one of the connections up to the resistor wire or the resistor wire itself is dead. You need to work your way from the ignitions switch toward the engine until you find where the test light stops lighting.
clb077
If I have a kill switch I have no idea where it is. My boat is a 1981 Glassmate Fish/Ski.
achris
1981... thinking thinking thinking.... Nope, don't think they had ignition kill switches back then.....
Looks like the resistance wire...
Chris...
(now? Can I post it now Don? :D)
