'81 merc t-n-t ?
BaDucK
from what ive been able to gather there is an older model tnt unit that uses pistons in place of the cylinders that are on my motor now, is this a simple swap the cylinders and find a pump/do the wiring upgrade that it sounds like ?
im going to do a search but if anyone has a quick answer id appreciate it
Moody Blue
Re: '81 merc t-n-t ?
Yep fairly simply upgrade. I did mine last summer on a 1971 Merc 800. Same TnT system was used from late 60's up till 1985ish. I had to make one of the fasteners that was missing from the unit I bought.
Biggest challenge will be to find a used system in decent condition. You will need the following parts .....
- external pump/reservoir
- mount for the pump/reservoir
- four hydraulic hoses
- two hydraulic rams
- two hydraulic ram mounts
- three button control panel c/w cable
- assorted hardware
You will need to remove part of the existing reverse lock linkage as well.
