OK so first I will list the the things I have done to this 70 Seahorse which resides on my Whaler Classic Sport 15.
Empty/clean gas tank
New fuel lines all around
New fuel pump
New filter
Rebuilt/cleaned carbs (all three)
New starter
New solenoid
New plugs(all three)
New thermostat
New water pump
Push in choke and turn ignition, motor fires once real quick, turn ignition (without choke) and engine
will fire after around 2-5 seconds of the starter turning, I may have to do this a few times before it quits coughing and throwing a mild backfire through exhaust, then it will idle and function normally as far as I can tell.
Turn off and it fires back up beautifully with just a mere tap of the ignition.Turn off and let it sit for a short time and its back to the sluggish cranky start.
Out on the water it's the same scenario for starting except for the bogging down on throttle and idle. After some frustrating bogging and restarting it magically kicks to life and its off to the races! For reel, its amazing! it goes and goes, WOT, MOT, idle, rev. no problems, cruise the bay at various speeds for an hour and again no problems, no noticeable variations of engine functions.
Turn off for a minute and restarts like a champ with just a tap. Let it sit for a drift across the channel (approximately 10-15 min) and its back to the hard start and sluggish idle that bogs out and quits on any attempt at throttle. After a frustrating rematch with this hard start behavior its back to the races, all day if I wanted.
Notes.
No noticeable water on plugs
When engine is in tilt position a small amount of what seems to be thin mix oil seeps from carb over time.
Fuel system seems to be working from tank to engine, firm bulb that does not collapse.
New fuel pump
New filter
New starter
New solenoid
New thermostat
New water pump
Notes.
