popeye_da_biker
Thread starter- Joined
- Jul 4, 2012
- 4
Ok so I finally got this beast running. Evinrude 115hp E115TLCIM. I guess it sat for a few years, but new gas, plugs, oiled cylinders, and a good cleaning of the carbs had it running with one turn of the key! (once i figured out how they rewired the controls....sheesh!)
My question is the bottom end, when hooked up to the muffs it leaks some water at the seam where the lower unit meets the exhaust housing. I've checked all the parts lists and there is no gasket listed for this location.... is this ok? a picture of the leak is attached. Water pump seems fine, but I'll likely change the impellers before any real use.
Before I water test it I want to change the gear oil as well. Does anyone have a guide for this, preferably with pics but ok if not.... first boat an I'm still learning the terms.... the motor was easy, not too different from a bike...
