When you say it runs great at high rpm's, does that mean on the trailer, or on the boat, running in the lake? Not sure if a complete ignition system from a blown powerhead would be a good thing. Guess so, as I'd probably take it, too. Let us know how the flywheel key looks. The coils on that engine are usually pretty reliable. Always have been. Unlikely they are responsible for the backfiring-unless wired wrong. Suggest you start testing the stator and the timer base. The cdielectronics.com website has an excellent troubleshooting guide for these crossflows. I like their cranking output voltage minimums for both these components. If both of these check out, and the power pack becomes the next suspect. You can test with these two. Check for spark on both banks. If you see weak/no spark on one bank, swap the identical power packs and see if the problem moves to the other head. Then you'll know it's pack-related. The fact that the engine does not recharge the battery is unrelated to the ignition problems you are experiencing. Another separate electrical system. Even if the power pack wires feed the correct coils, check to see if the coil wire goes to the correct plug. I bought a V6 once and the middle coil fed the bottom plug, and the bottom coil fed the middle plug. Pretty violent backfiring from that. That took a while for me to figure out- many years ago.
