81 evenrude 150 sinking bank acct
cabot
replaced all ignition parts,checked compresion(80psi) power packs,stater,timer base. magnets on flywheel seem strong.made sure floats wern't sticking.even checked for open primer solenoid.still sounds like its loading up,and miss fires.can't even get a strobe on the timing light. going to look at reeds now, then i'm going to lite it on fire to really watch my money burn
Hooty
Re: 81 evenrude 150 sinking bank acct
Holy Smoke ! <br />I guess that's a bad choice of words. I curious about the part where you "can't even get a strobe on the timing light". Do you mean there's nothing to fire the timing light?<br /><br />c/6<br /><br />Hooty
Joe Reeves
Cabot.... You state what you have replaced, and say that it sounds like it's loading up, but that doesn't tell us very much.<br /><br />However, judging by what you've replaced, I would assume that you've been having a problem with the ignition system.... and weak ignition would cause the engine to misfire and load up.<br /><br />Remove the spark plugs, rig up some kind of spark tester whereas you can set a 7/16" gap. Have someone crank the engine with the ignition key while you check the spark (check all the cyls). If the spark is either weak or non existent, do the following.<br /><br />Disconnect the large RED electrical plug at the engine. Using a small jumper wire, jump from the battery terminal of the starter solenoid to the small 3/8" hex nut that energizes the starter solenoid (not the 3/8" hex ground nut). If you now have spark as it should be, there is either a short in the wiring harness somewhere or a shorted ignition switch.<br /><br />It's usually the switch..... replace it if the above is an improvement.
cabot
thanks Joe Reeves for the info about th shorted ign. switch did the test you advised, seemto have good spark. are 8mm wires correct fo that engine? found a clogged jet in 1 carb and a few dirty ones. seems to run better,but still has a backfire at idle,but verry responsive if i advance throttle quickly. going to test engine performance tomorrow. thanks again joe. :)
