Bottom carb. At idle, you can see fuel spraying against the back butterfly. The fuel then accumulates and drips out the front of the carb. Engine will not lift the boat onto plane; just plows through the water. Previous owner let fuel get wet. I have clean fresh fuel in a clean tank; dismantled carbs and cleaned; cleaned fuel screen; installed new plugs gapped at .030" (all firing), no unusual smoke. Any repair advice and/or recommendations for a GOOD troubleshooting/service manual would be greatly appreciated. Thanks.
