relics hunter
Thread starter- Joined
- Jun 11, 2010
- 118
I've had it out a couple times trying to work out the problems then the stator died. I have a good looking used one in place and upon starting it the idle was way to high. I think I now have it set correctly to start reliably, the manual say's the roller should be set at the lower mark but it seems to want to be centered between them (which makes sense to me). I think I have the carbs synched but it's just a little rougher then before the stator went. I have the omc manual for it and I'm a little disappointed with it. RPMs are 1100 in a tub so it should be about right on the water. Is the only adjustment, the trunnion nut? The idle stop screw is against the stop, so that's good unless someone messed with that screw.
The throttle is my next problem. When out on the water it got up and planed pretty good, but the throttle linkage at full open is no where near what the book pictures. I have to firmly push the lever farther then I think I should and the roller cam is just a little up the plate ( see loer red circle). Is the upper stop screw stopping it from advancing(upper red circle)? I had an old mercury that didn't throttle up right and the problem was in the control box. Is there something in there I should look at ? I was getting about 4800 rpms out of it, so it's in range. The boat is a bit bigger then it should be pushing, but it's a light boat, just wide. What do I adjust to get better response on the throttle and not wear the handle out.
