olemerc115
- Jul 6, 2008
- 28
just wondered what the factory settings were on a inline 6 2 stroke 115, on the idle mixture scres, I think they are set at 2 turns out on all 3 carbs but I cant remember, I checked mine and they were at 1 1/2 out and was bogging until planed off, then I set them to 2 1/8 it helped but it still wants to bog on the bottom, I pumped the primer bulb while bogging and seemed like it got worse, I reset them to 2 1/2 out today gotta take it out soon, I acts like it isnt getting enough fuel, but I dont know, I have posted before but the compression is good and the plugs are not steam cleaned so no water in the cylinders, this bog until planed is a real pain, thought I had it fixed but I guess not, I am thinking it is in the carbs and not ignition related becuse when you hit it while planed off it screams and will run fine, also when loading the boat onto the trailer, once you have the boat on and you give it some throttle to ease up, more on the trailer, it bogs and want to stall out, like it has no power to drive itself up on the trailer any farther, I know this isnt right because you see other people throttling there boat hard and it goes all the way up on the trailer, I gotta get this motor more throttle response on the bottom, it should have more torque than it does, any help please and thanks again
