80s 35hp Johnson Cables?
drewshep
I have an 80s Johnson 35hp long shaft motor and it needs new shift and throttle cables. A shop wanted like $250 to replace them, which i think is insane. I am plenty capable of replacing them my self, but I have no clue on what cables to buy? Could someone help me out?
F_R
Honorary Supreme Mariner
Get them right here at iboats.
Edit: Type 479, assuming your control also is 1980's. Pre '79 was Type 400
drewshep
Ok i found that cable but there are two cables on my motor so would i buy two of the 479 cables or are there two different cables i have to buy?
oldboat1
Can always check around -- look for a small shop rather than a large marina, and keep in mind it's Spring.
F_R
You need to order two cables. They are alike.
oldboat1
If doing the installation yourself, I would pull off the current cables to check the type and to measure -- although you might still decide to just leave it with a shop (again, good to check around). Are the cables no longer functional -- seized or binding? Maybe there is an issue with the control box.
drewshep
The cables are rusted out and almost seized. I took the boat to a local shop for a look over and he said the cables needed to be replaced. This was a couple mouths ago.
F_R
He is charging you for shop labor rate, plus ++. Such a simple job as that is within the novice's ability. Some depends on the boat. Are the cables easy to access? Or are they all tied and taped together with a bunch of wires etc,?
I have a suspicion that he was expecting to do more work than just the cables. Maybe your ears perked up and "cables" was all you heard??
Shop rate is shop rate.------------You may have an old motor but their time is all brand new and needs to be paid for.---------$ 100 / hr + parts adds up quickly.
drewshep
Nah, it was just cables he was talking about. There super easy to get to.
