CobisCaller
Thread starter- Joined
- Jul 22, 2009
- 32
I was wondering about the process to troubleshoot the cooling system on this motor. There is barely a trickle of water coming from the pee hole on the motor. I replaced the water impeller last season with the same issue and it improved some, but still didn't seem as strong as I remembered in the past.
What other parts/seals could be restricting the water or leaking?
I did blow air back throught the pee hole and it doesn't seem plugged there.
Thanks for any info
Josh
Thanks for any info
Josh
