I'm new to outboard motors, but not to motors in general and am having an issue with an '85 Johnson 8hp outboard.
The engine/thrust surges at all throttle positions and in neutral/forward/reverse.
The primer bulb is tight and the ss/needle valve has been adjusted in order to keep it running as best as possible.
We would get a second or two of full thrust followed by what sounded like the engine was starved for fuel. But what was weird is the gaps between thrusts kept getting smaller until it went wide open and operated great for about 30-45 seconds and then went back to surging.
The gas tank and associated fuel lines are pretty old and felt like they were too small for the connection to the motor. Could the motor not be getting a good fuel supply.
I appreciate any help you can provide.
Thank you,
Thank you,
