79 merc 150 no spark #1 cylinder
BENGLER
I have a 79 mercury 150 and there is no spark at the #1 plug. I swapped plug wire with another cylinder still no spark, I swapped coil from another cylinder and still no spark, checked continuity on positve wire from power pack to coil and that is ok. Power pack problem?? any ideas guys... Thanks!!
BENGLER
Re: 79 merc 150 no spark #1 cylinder
Thank you, now I have read not to buy a mercury one. Is that true? If so do you have a link where to buy one or where do you recommend to purchase them??
Laddies
Banned
Mercury CD parts are the pits, CDI is the best replacement.
BENGLER
I know this is really dumb, but this is my first boat but what is CDI? is that the brand? do they have a website? Thanks again:redface:
BENGLER
nevermind I just answered my own question, thanks again for all the help. I will let ya know if it fixed it.
BENGLER
crap biskets!! I replace both switch boxes and still no spark on #1. Help please
Laddies
Banned
Have you tried to use the #1 output terminal of the box with a jumper wire to a differant coil that you know will fire, it's beginning to sound like a bad wire or coil some where on #1 cyl.
j_martin
coil ground wire on #1 cylinder.
That's why we troubleshoot with meters before we start throwing parts at it.
hope it helps
John
BENGLER
I ohm checked both the ground wires and the primary wires before I even posted this forum and they all are within spec. This is really messed up and does not make any sense
BENGLER
Well found the problem, the trigger assembly had a open wire going to the switch box. Replace the trigger assembly and we have spark on #1. Thank you for all your help.
