79 johnson lower unit removal
wtyner86
I took the four bolts out of the bottom and the nut on the back,.. what am I missing? I took the little plate off the side with the 2 flat heads and it looks like i can disconnect the shift cable there.. but its a small hole and i hate to do it and not be able to reconnect it.
wtyner86
Re: 79 johnson lower unit removal
If anyone knows the answer to this, you can call me. I'm working on it right now and can't wait by the comp. 205-764-4010
wes
dew2
This has to be a older double post,In another post earlier to day he removed lower installed impeller and is concerned of water flow.I believe hes dropping the lower again to use a hose and water up the water tube.
