79 Johnson 85HP need to remove lower unit but cannot shift in to reverse
duckman028
79 Johnson 85HP need to remove lower unit but cannot shift in to reverse, I need to inspect the forward gear and all videos say about shifting in to reverse. is there an alternate way and why must it be in reverse? Thank you Dave
jimmbo
Have you tried rotating the propshaft as you attempt to shift? Putting it in reverse probably puts the shift rod in a position that makes it easier to disconnect from the linkage
Snebber
I removed the lower unit on my 81 90hp without shifting into reverse. Getting the clevis bolt out was a pain in the butt. A tech told me putting it in reverse makes it easier to get the shift rod back into place when reinstalling the lower unit and trying to replace the clevis bolt.
