Hi, I'm the new owner of a 1978 Marquis with a 70 HP Johnson 70EL79. I took it out the other day, and on my first outing it did great, and I opened it up and it had good speed and the engine sounded great. I docked it for a while and then took my wife out later, but the engine kept stalling. I used a little starter fluid, and it started back up and ran good. We went to open it up more, and then with the throttle up higher it died. After that it was difficult to keep it started. I should add that the previous owner told me he had problems with starting occasionally, and usually keep the carb cover off to make it easier starting with starting fluid. Once running it usually runs really good. I have had it going several times now. I'm going to start with the carbs, especially since he has had problems starting it before. Any other ideas?
