'79 Johnson 6hp - Spark from only one plug.
jcmonty
Motor was running very rough so I pulled both plugs on the motor. One was dirty and the other was squeaky clean....too clean as in not sparking. Checked the spark and as I thought, dirty one was sparking, clean one had no spark. Replaced plugs, same result. Pulled off the plug boot, connection looked OK. Checked connection through coil, multi-meter read ok through coil. All the electrical connections seemed fine, which kind of stunk because I thought the culprit was the coil. Could the coil still be the problem even though the electrical connectivity seems good? Any ideas to continue troubleshooting this? Powerpack possibly? How do I go about checking it? Thanks in advance.
Cody
boobie
Go to cdielectronics.com for trouble shooting procedures.
jcmonty
Looked......didnt find much past what I had done already.
oldboat1
not my favorite tinkering, but should be able to do some basic tests using those online instructions. Maybe you have done that. For ignition coil testing, try http://www.penn.itgo.com/video-pages/coil-testing.html . The Penn instructions pertain mostly to magneto ignitions, but testing should apply to your coils. Be aware that a clean plug could be washed, meaning you have water in the cylinder (can be a bad head gasket) -- a washed plug is pretty obvious to spot, and may not be what your are describing.
Use an adjustable spark tester for ignition testing -- look for about a half inch, and work backwards until you find spark. I would run a compression check as well. There is an outside chance a flywheel magnet has failed, so check the magnets.
Chances are it's a power pack, but the pack is an $80 plug and play item and there are no shop costs....
