Motor was running very rough so I pulled both plugs on the motor. One was dirty and the other was squeaky clean....too clean as in not sparking. Checked the spark and as I thought, dirty one was sparking, clean one had no spark. Replaced plugs, same result. Pulled off the plug boot, connection looked OK. Checked connection through coil, multi-meter read ok through coil. All the electrical connections seemed fine, which kind of stunk because I thought the culprit was the coil. Could the coil still be the problem even though the electrical connectivity seems good? Any ideas to continue troubleshooting this? Powerpack possibly? How do I go about checking it? Thanks in advance.
Cody
Cody
