79 Johnson 55 HP Won't Start after warm
Okieducks13
A buddy of mine picked up a 16 foot flat bottom with a 79 Johnson seahorse 55 hp for $300 from a family friend cuz it had been sitting for 3 years. After getting all the lower unit seals replacing and putting in a new water pump we thought we had a cheap duck boat. Problem were having now is after running it for 5 minutes or longer it will not start back up. We can drive across the lake at full throttle with no issues but backing off the throttle to idle and trying to get it started again just don't work. I rebuilt the carbs and that had no affect. We know it isn't a fuel issue. He took it to a family friend who owns a repair shop and the guy told him it was the carbs, he cleaned them up and still the issue is there. He then took it back and the guy told him it was a coil pack which he replaced and it still has the issue. Needless to say I'm not impressed with the guy but my buddy wanted a "professional" opinion on it. Finally the guy tells him it's probably losing compression when it warms up. I'm not convinced. My personal opinion is that it is probably an electrical issue, most likely the stator. I plan to check spark and compression after I warm it up in a few weeks when work slows down. Has anyone had a similar issue and am I on the right track with an electrical problem or is it more likely compression?
