79 johnson 25 hp will not stay running
clecun
I recently bought a 1979 25 hp johnson. It ran poorly when I purchased it. Compression was 100 on both cylinders. Cleaned carbs, new fuel lines, rebuilt carb. The motor was running great when I first got it back together but the next when I went to run it again in a tank and now it does not want to run. I can get it to start but it will only run for 3-5 seconds. Even when I give it throttle it starts up revs up and dies with in 5 seconds. Any advice would be great.
pn
Re: 79 johnson 25 hp will not stay running
Take a close look at your electrical lines to make sure nothing is grounding out on the stop/start wiring. Clean out the carb again. or look at fuel pump. good luck.
clecun
I have cleaned the carb like 3 times soaked and also sprayed out all jets. Thought my float might have been upside down but it won't even crank when the float is in the other way. The fuel pump has also been rebuilt. If you disconnect the fuel line from the bottom of the bowl and squeeze the primer bulb it flows a bunch of fuel. There is fuel in the carb yet it only runs for a few seconds. If i try to squeeze the bulb as the motor fires over it still dies in a few seconds. I will look over the kill switch but I figured it would have no spark if that was my issue. Just for the record this motor is a pull start only.
