Alright..
Boat is up and running here is the problem.
It start to overheat very quickly when it is in the water and we try and go over 2000 rpms. The temp gauge start to shoot up to 180 - 200 then 220... if you back off the boat starts to cool down and come back to 150 on the temp gauge.
Also the Gimbal bearing is making a racket at the 2100-2500 rpm mark....
I think somewhere in the outboard is the problem. I know the water impeller was replaced last year...
Would it be cheaper to just buy another outboard or the lower section of the outboard?
Thanks for the help guys. (pics to follow)
Save your money on the ignition and carb, rebuild what you already have. You will not gain major improvements "upgrading" them. Put the money you saved towards new manifolds, so you don't destroy the engine.
Alright..
What type drive is mine? Pre-alpha? (Mechanic said 888 but that sounds wrong..)
I need to order the raw water pump.. Impeller kit and the Gimbal bearing..
