I have I believe a 79 Evinrude 25hp. Worked fine last fall. Now doesn't shut off with the key. Have to choke it to get it to stall. I replaced the ignition switch but that didnt fix it. I checked both wires labeled M at the ignition. Both are grounded with key on or off. Have continuity between them only with key off. I have a good ground on the motor and the outboard housing itself. Don't know much about outboards. Anyone have any suggestions on what to check next?
