jayperry01
Thread starter- Joined
- Sep 21, 2015
- 1
I have a 79 Evinrude 70 HP that I bought a few months ago. Sat up for several years but was started regularly. It ran fine when I first bought it. Took it up to about 30mph but she idled rough and was a little hard to start. I bought a carb rebuild kit from iboats and rebuilt the carbs. I did a real good job. They were like brand new when I got done. I was proud LOL. After I put it together she started right up without even needing the choke. Went to put it in the water and it wouldn't start with the lower end in the water. If I tilt it up out of the water she will start but die when I lower it back down. Furthermore, if I can get it into gear before she dies, it will run but the boat has no power and goes about 6 mph full throttle. So there must be a fuel delivery problem. Its demanding more fuel under load but something is impeding the flow. I bought a new fuel pump rebuilt kit and rebuilt the fuel pump/filter assembly. Another proud job. I checked the fuel lines for leaks and bad spots. Replaced the fuel line/primer bulb from the tank to the motor. What can it be? I had it on the water again this weekend testing it. Had it full throttle going 6mph and for a moments time it opened up and took off like normal. Probably up to about 35mph this time but then bogged back down. I know compression is good, other engine components are good. It is something within the fuel delivery system, or the carbs. Can someone shed a little light? I attached a video ===> https://flic.kr/p/yVdVaz
