79 Evinrude 25hp oil leak
Frank98284
Oil in water of test tank also black oil coming out of hole to the left of top fill hole of lower unit I pick it up off of Craig's list cosmetics looked like some had taken care of it for its age.
Thank you inadvace for your help
Frank
GA_Boater
Welcome aboard.
What's the question?
Making a stab - Oil in water from running a 2 stoke is normal and you need new gaskets on the fill and vent screws I guess.
Honorary Supreme Mariner
Sounds normal to me.----That may well be the oil that is mixed with the gas.----Time to review how a 2 stroke operates.
Frank98284
I am aware how the two stroke works I put new gaskets in fill and drain screw holes but the is what looks like oil coming out the hole to the left of the fill hole
Well,---that is a drain hole to prevent water from freezing in casting cavities.--Directly connected to the exhaust housing.---Were you running in a barrel for a while ?----If you are worried about a gearcase leak then pressure test the lower unit !!---That eliminates the wild guess work.
