Timer base tested bad after boat only ran on two cylinders, already put new coils and power packs so thought it had to be the base. according to the manual, base and stator test good, but no fire, even on the two cylinders that were working before
Did you replace these parts with new ?
check all your connections make sure you have good grounds. Make sure you didn't push a pin out of a plug.
after checking all of this try unplugging the black and yellow hill wire and see if you get spark.
If you do get spark it means something is grounded out somewhere from where you unplugged it up to the key switch. Key switches have been known to go bad. This might have been your problem all along. But please know I'm not a master marine mechanic there is some here that are but they must all be at the lake lol
One simple way is to unplug the big red connector and jump across starter solenoid to see if you get spark if so then work your way forward to the switch. Or just pull black and yellow wire from switch and test. Do you have a lanyard kill it hat clips to you incase you fall out? If so check it also
Agree with post #11. That removes the key switch and the control box from the equation. If you jump the starter and get spark- you know the engine and it's ignition is ok. Key switches do go bad, esp if they are exposed to rainwater.
Ok had some bad connections now have fire on all four cylinders but motor is still only running on two cylinders, the top and bottom cylinders on the same side as the big red plug are not firing have compression and spark but no fuel????
What do you mean big red plug no fire??
it seem a little odd that a fuel problem would show up on both carbs same size it anything is possible.
how long has the motor been sitting?
what are the compression numbers for each cylinder?
does spark jump a 7/16 gap?
If you pull the spark plugs and crank the engine over, you should see some fuel mist coming out all 4 spark plug holes. You say but not the port head holes?
No, plugs are dry, and no mist when you remove them. don't know numbers yet on compression but seem to have great compression, pulled carbs off and cleaned them but same problem, does not make since.
It seems really odd for both carbs to be plugged up on the same side but anything is possible. Remove carbs and clean them then clean them again before putting them back together. Use carb cleaner and spray through each orfice ( refer to manual to make sure you get all orfices ) . The only thing I can figure here is you didn't run the motor out of fuel at the end of season and the old fuel settled to one side of carbs and has gummed up .
