The cable assembly between my remote and engine has a bad wire in it. The wire that causes the temp. warning horn to sound is open. I can wiggle the cable right in front of the engine and get it to work so I know where it is broken. I have extra cable available, coiled up in the rear of the boat. Does anyone know where I can get the red connector that is on the end of this cable. I want to cut is off, pull some of the extra cable into the engine, cut off the bad area and put a new connector on. I have only found diagrams showing whole cable assembly and that is no long available.
