79 6hp Crysler OB
ztim
After storage for about 4 years, I got the motor running. On the lake all was fine until going back to the hill. I got out of the swamp and gunned it, and the motor coughed three times an died. Any ideas would help. Bob
Drowned Rat
Re: 79 6hp Crysler OB
Need more info Bob. Did you check the water intake after leaving the swamp? Did the motor overheat or make any sounds before it died? What happened when you tried to start it later? Nothing wraped around the prop? Primer bulb still full? Spark plugs fowled? Using 50:1 TCW3? Try posting some additional info and you'll get an answer. :)
