The starter solenoid will not pull in using the ignition switch but works fine with a jumper from the positive side big post. I replaced the ignition switch but that didn't help. I have 12v at the solenoid with the key in the start position but apparently not enough amps. I cleaned all the connections including the big red plug pins. This situation was intermittent until today now its full time. There is no neutral safety switch on this engine. Any ideas would sure help. Thanks Sherm
