'79 115 evinrude carb sticking
airslot
my v4 runs just fine for about the first couple of miles but after that she begins to sputter then eventually bogs down in what seems like a depravation from fuel - also my viewable fuel filter will go dry - but even if there is someone keeping the filter pumped with gas, she will still sputter - however if I back off on the throttle she will stay lit & even runs ok at about a 2500 rpm - has anyone else experienced this problem?
D
DJ
Guest
Re: '79 115 evinrude carb sticking
Where is the fuel filter you mention? Which side of the primer bulb?<br /><br />Is this a remote fuel tank, or built in?
airslot
it is one of the 6 gal. portable tanks using the visible quick inspection type filters -
D
DJ
Guest
First off, that filter should never go dry. The only reason it would is:<br /><br />1. There is a restriction in the fuel tank outlet.<br /><br />2. There is a restriction in the fuel tank vent.
airslot
for the most part I can keep fuel in the filter, at least a 1/4 - 1/2 full which is usually enough for the proper flow to the engine - the bulb is on the tank side of the filter - <br />but it seems that the problem may be in the carb - I've had one person tell me that the float is sticking & another tell me that it was a vapor lock - the carb hasn't been rebuilt snce '99 so perhaps it's due - what do you think?
D
DJ
Guest
Actually, you have two carbs. and a fuel pump.<br /><br />I think I'd look at the fuel pump first.
airslot
you're right 2 two barrels - & one pump - I thought the pump worked off the # 4 piston???
D
DJ
Guest
It works off of crankcase pulses. It may be weak.<br /><br />The pump rebuild kits are inexpensive.<br /><br />Be careful taking it apart, there are lots of little springs, and stuff in there.
airslot
I'll give it a try - I have the repair book, probably safer that way with all the springs - thanks for you responses - take care..
