'79 100 HP Started Like At WOT
Wildcatford
Hello,
I have a 100 HP Johnson 100TL79S Javelin Motor picked up recently online ($300 for a boat and motor both with title!). It's been sitting for a few years, so I went through it.
I am stuck and looking for help. I have visited the stickies page and read the "why won't it start" and "cold starting procedures" but here I am.
Have Johnson service manual on hand. JM-7909
Brand new 12v "1000 Marine cranking amps" battery charged over night.
New wires from battery to starter/solenoid.
New Solenoid.
New Starter.
Neutral switch jumped for testing.
Kill switch bypassed for testing.
Have spark on all four plugs (Checked with light, and held to motor)
Carbs rebuilt
No flooding when primer bulb is compressed, but does build pressure in balloon.
New fuel lines
New fuel pump
New impeller
Replaced lower unit gear oil.
Replaced tilt/trim solenoid (now tilt/trim is working!)
New ignition switch, and harness to motor.
All connectors looking old or inadequate have been replaced.
Fresh Gas and oil.
New temporary 3 gallon Academy fuel tank for testing used. Vent open.
I have not performed a compression test, because I'm too scared too (haha). Plus it's too fun working on these things. I have a compression tester.
Didn't dig into power packs as I had what I thought was good enough spark.
Anywho. I got everything put back together, battery charged etc. and after what seemed like forever of watching the flywheel turn, it started like it was WOT. Fearful for the motor, I just shut it off.
The warm up lever was about 3/4-7/8 of the way up, but I was in neutral straight up.
Pulled back the warm up lever to closed- cranked again, and it fired right up and idled normally for about a second then died before I could choke it.
The battery is now dead, but I'm looking for something to check on before I try again. Having it start at WOT was unnerving.
What could cause this? My first thought was air leak or synchronization & adjustments.
Or is it just that it hasn't been run in 5 years, and I need to just try it again?
Looking for any advice to help.
Love the site. Thanks for your consideration.
oldboat1
Think I would also want to check the remote cables and connections. The old style ends use set screws to clamp on to the cables -- can come loose and the cable slips. On examination, you might see a cable problem fairly quickly.
If nothing obvious, standard procedure is to disconnect cables at the engine, and test throttle and shift using linkages at the powerhead.
Honorary Supreme Mariner
Perhaps check the flywheel key.----You really need to check compression on a 40 year old crossflow V-4.
Wildcatford
Ill check out the linkages, synchronization, and flywheel key.
I bit the bullet knowing that the "check the compression" posts were coming. 89-95-100-94.
interalian
Checking flywheel is OK is easy. Just pull #1 plug and put a long pencil straight in the hole. Turn the flywheel by hand until the timing pointer is at "0". The pencil should be all the way out, showing #1 is at TDC.
Wildcatford
Interalian- am I concerned with where it stops going up, or that its at TDC when it hits the mark?
It is at the top when its at the marking for TDC, but its rise stops before it gets to the marker. I hope this makes sense.
flyingscott
My guess would be you had the warm up lever to high. Try just pushing it up just until you feel resistance. In neutral a little is a lot on the warm up lever. Reconnect the switches you bypassed especially the kill switch. For the compression test the the kill switch wires together to kill the spark. I could make a motor like that overev in neutral on 2 cylinders.
interalian
TDC is TDC. When the needle points to the mark, the piston should be at top of travel. When you test with the pencil, the piston seems to stop early as it moves very little as it nears top of travel. This is what you're probably feeling.
A more accurate test, and the way to align the pointer on a rebuild is to use a piston stop (I made one by breaking an old spark plug and tapping it for a 3/8" bolt) screwed in the spark plug hole so it contacts the piston top a few degrees before TDC. Then:
Turn the flywheel gently by hand in one direction until the piston contacts the stop.
Mark the flywheel where the indicator is pointing.
Rotate the other direction until the piston contacts the stop.
Mark the flywheel again.
Split the difference between the two marks you made, the middle mark is TDC.
Wildcatford
I went back out today, and when I started going over flywheel noticed that my idle speed adjustment screw wasn't touching the stop.
I followed the arm to the linkage, and the linkage was about 1.5" too loose. I tightened her up. Will see if this is it or not once I get the kids in bed.
if I wake them up, for once it will be a good thing.
I will report back. I hate reading threads that the OP decides to go Houdini once its fixed. It's not helpful for the rest of us, and is kind of the point of coming here for help if you ask me!
I'll let you know if it solved the issue, or come back and ask for more help -ha
oldboat1
If you can get that big sucker in a test tank (plastic trash can....), the kids can stay asleep. Also will be better for idle testing. Need water level six inches or so above the impeller.
Wildcatford
Took her out, hooked her up, and she fired up like she hadn't been hibernating the passed 5 years... It was the cable. And I couldn't be more thrilled. Thanks for the help all.
I'm having a blast with this project. Now my family thinks I'm somewhere in the range of Gutenberg, the Wright brothers, and Henry Ford mechanically. Ha!
