Re: 78 Starcraft home made welded canopy
Some interesting reading on this one ,
crevice corrosion occurs between aluminum sheet or other crevices with trapped salt water or even trapped freshwater with some mineral content where oxygen cant get to the surface of the metal , pretty common stuff here, see it alot on aircraft floats , water hulls and in other places depending on the alloy it can be fairly common. Zinc chromate and a good sealant on the faying surfaces ( not gluvit ) can go a long way in combating it especially when the rivets are installed and driven wet with sealant. (PR 1422 , Pro seal 870, both have chromate in them and remain flexible indefinetly ,used to seal wet aircraft wing fuel cells and water hulls in aviation)
50 series aluminum is pretty corrosion resistant(much better than 20 series aircraft aluminum)
and can be left bare as within hours an aluminum oxide coating coats and protects the metal underneath, galvanic action and crevice type corrosion are the two main enemies facing the underlying metal. Salt water isnt acid , it just acts as a far more efficient electrolyte than fresh water.
It takes literally minutes to replace a rivet if you know what your doing and have access to both sides (solid), even less time if your using a blind rivet and both types installed and driven in the case of a solid wet are waterproof. They work primarily in shear not tension so make sure the application fits. 5052 waterproof blind rivets are certainly available and I'd recomend you replace them rather than gob on gluvit if you've got a leaker, if its leaking its most likely fretting as well which is another form of corrosion and a dead giveaway is rivet smoke ( aluminum oxide) around the affected rivet.
I dont mean to preach but it seems to work pretty damn good on all these beavers and otters flyin around here sitting in the salt year round landing and taking off in salt water day after day and the helicopters I work on hovering and manuevering in salt spray servicing ships and lighthouses.
Thats a pretty nifty cabin you've built there and It certainly looks dry and comfy, did add a fair bit of surface area to her though. Your gonna have to let us know how she fairs in a gale with a good swell and 3 or 4 feet of chop.
