'78 OMC 2.5 wont run.........HELP
poppasmurff
Ok heres the scoop. I recently bought a '78 cobia w/120 GMC and a 400 OMC outdrive. I purchased this boat from an elrly gentelman who would only go out once in a while to tool around to his fishing spots on the river behind his house. He had pulled the originale fuel tank and replaced it with a 5gal john-boat tank, it seamed to work but 5 gal was kinda small for me so I replaced it with an 18 gal fuel tank. I have since found out that my distributer shaft has lateral play and to try and adjust the points is immpossible . When I got the boat it started on the first try and ran ok but seemed to be lacking in RPM at WOT.(3600-3800), and now the boat won't even start...it will fire but run rough and stalls right away. Is this consistant with the points/distributor issue? We were out on the boat a week ago and were enjoying the day when it seemed to run outta fuel. I checked and fuel tank not empty but boat would not re-start.....killed the starter. this issue is plaging me now. HELP!!!
chiefalen
Re: '78 OMC 2.5 wont run.........HELP
This new fuel i heard messed up alot of old tanks.Thye were filber glassed lined or whatever.
Yes you need a new dist. or a good used one. I see them on e-bay all the time. Just saw one yesterday do a search omc dist.
I'm surprised it ran to 3800.
Maybe someone will come bye that has one
Good luck
poppasmurff
Well am looking into the distributor problem also rebuilt the carb,replaced the plugs and am waiting on some plug wires a cap and rotor. After the carb rebuild, motor ran great for about 20 sec.....I think The ignition is weak....and loss of spark is what my issue is.
