fishingdude81521
Thread starter- Joined
- May 19, 2017
- 11
hi I have been reading on several forms about the no spark on the 78 merc. 900 90HP inline 6. I found several forms talking about removing the 3 wires from the switch box and jumping the white and brown wire then removing the coil wire to ground it to test the trigger. the all say what it is if it sparks.. but what if it don't? I filed off some paint on a bolt to make sure I was getting good ground I tested it with a light to make sure and it was. when I hold it near the clean spot and ground the black wire. ( top post) there is no spark. is there a way to test the switch box? or coil?
Thanks
Thanks
