78 Johnson 55hp core plug
Navajo
I've taken the core plug off the carburetor above the low idle orifice. How do I get the replacement one back on? The book says to use a flat punch and hit in, but the new one is a much smaller diameter. If I set it over the hole it actually falls down in. I flattened it out a bit and it will now set on the opening, but it is still much smaller. Is this typical? I don't want to start tapping on it and jam it down in the hole.
Any advice?
boobie
You've got the wrong size plug. Get the right size from your dealer.
Navajo
Ok Thanks. That's what I figured. It does have the correct part number on the package so that's what had me stumped.
