buffbenj
- Jan 30, 2012
- 33
Bought a model 28EL78C 25 hp Johnson on a small bass boat. Was told it only needed a power pack. Ordered for $55 and installed. I assume the small single black wire on the power pack is a ground, so I attached it to the block. Old magneto had already been removed, and new one does match up. Cleaned fuel filter. Fuel pump works. It will start and run for 1-2 seconds with starting fluid, choke or no choke. Sure seems like it is not getting gas. Primer bulb is firm with pumping and feels normal. Seems the next step is to pull the carb and inspect and clean. Any other advice? I also have no idea what the factory setting for the mixture screw should be. Right now it is about 3 revolutions out from fully tightened.
