mirage5058
Thread starter- Joined
- Jun 2, 2008
- 60
I picked up a 76 grady white 120 hp omc motor and outdrive i got it running great,the outdrive did not work when i got it also it just swings up and down with no resistence like it is not attached to anything,i put in new tilt motor old one was siezed,motor works now but the outdrive(OMC) does not go up or down even with new working motor you can lift the outdrive up and down by hand the gear is okay i put new oil in gearbox,i dont know what the previous owner did but i know the outdrive should stay in place and you shouldnt be able to lift it up and freely,is the something i am missing to engage the gearbox so the drive will stay in place and raise and lower like it should?Any help would be appreciated when i took the middle gerarbox cover off to clean and check i noticed the clutches seem okay,My main question is why does the l ower swing up and down freely and wont go up and down using motor?
