'78 evinrude 9.9 how much oil in lower unit?
JohnVH
Ive been searching for an hour, cant find any spec on amount or type of oil.
Thank you
jmendoza
Re: '78 evinrude 9.9 how much oil in lower unit?
Takes less than 1/2 quart, I filled mine twice from a quart bottle. Buy the BRP synthetic gear case lube availlable at your Johnson/Evinrude dealer(IBOATS), or Sta-lube makes gear case lube for outboards, try a marine hardware or NAPA.
Be sure to get new nylon sealing washers for the fill and drain plugs, and torque them as they will leak if not tightened correctly.
JohnVH
Excellent, thanks so much!
