Re: 78 70hp evinrude idles way too fast
Rex, what linkage are you referring to? I do not know what the abbreviation "dis." is referring to.<br /><br />If I set the timing to reduce the rpm I have to retard it to 10ATDC, where the spec says it should be around 4BTDC. Are you saying I should ignore the engine spec and retard the timing by 14 degrees?
