fishinrado
Thread starter- Joined
- Nov 8, 2006
- 137
rewired the ingnition, put some fresh fuel mix into her , pushed the key in (found the key on the floor in a rotted handfull of stringer prior to gutting it out) and to my surprise the choke's closed as billed. turned the key and i'll be damed if the motor didn't fire right up! purred , heated up and began to uptake water into the lower unit and dischage. put into gear and with a small thud off went the propeller forward and reverse. this was in my driveway with water muffs. ran for a few minutes and turned off. waited and fired right up. same and same again.
what next? what to look for signs of trouble? or what should i replace to aviod trouble?
as stated in earlier threads this motor has not been run in years and was sitting out in a parking lot for who knows how long on a rotting away crestliner. is it too good to be true this thing just fired right up???? and then just restarted with ease? thanks for any input!
