At some point we are all new!<br />My 77-70 on my '67 Boston Whaler recently acquired ran fine except at idle. Dies shortly after going into gear. I use to be pretty good at outboards, (during the '60s).<br />Shop in San Angelo did carbs but bottom one would not adjust. Swapped carbs around, trouble stayed at the lower one.<br />Pulled powerhead apart to replace bottom seals. Found scored cyl and some rust. (Engine was used in salt water). Tech says bore and rebuild pwr hd will make it a strong engine. Can anyone comment about this. Would appreciate any help, especially from you pro's. Thanks
