77 evinrude will not shift into forward
jery
goes into reversed good but doesn't quit go into forward, if the cable is off then it will go into gear, I have ajusted the cable but, when it is to tight the control arm gears jump out of place therefor i have to take it a part and reset it, it seems like the control arm or cable does not pull it far enough to engage the gears
rickdb1boat
Re: 77 evinrude will not shift into forward
jery <br /><br />Cable or Control is defective. More than likely, it's a worn cable. Free the cable at the control and the motor. See if it slides in it's housing easily. If it binds, replace it.
