Ninja_C
Thread starter- Joined
- Mar 17, 2019
- 6
Hello, new member here. It's a 77' 55hp (model #55773d) Recently got this motor for my 1648 and it seems I'm missing the spring pictured. I'm having some weird symptoms I believe could be related (wants to die when out in gear at low RPM, runs perfect WOT, issue idling unless choke adjusted manually on water). Does this seem correct? Or sounds like I have a bigger issue? No issues at all when running with muffs or in a barrel at the house. Only while on the water. Thanks in advance!
