77 evinrude 85hp
tylerevinrude
i have a 85 hp evinrude that i juld cust replaced carb kits and decided to take it out and it would crank up and warm up ut when i go to pump the bole on the fuel hose it would not expand back out then i took the fuel hose off the motor to see if it was pumpin gas and it wasnt i was wondering if it was something wrong with the fuel tank cause i have an old metal one if it was not gettin air or what but when i have it sittin at my house hooked up to muffs it runs fine but it still sucks the bole on the hose dry when i squeeze could i get any help on this cause i sure dont wanna take it somewhere if its an easy fix
D
DJ
Guest
Re: 77 evinrude 85hp
A flat primer bulb is the sign of one of two things.
1. The fuel tank is not venting.
2. The primer bulb is installed backwards. There is an arrow indicating the direction of flow.
DamianJP
Theres a check valve in the "ball" thing you pump might be bad.
Also like you said check the tank too, should have a vent hose coming from it. Hose should lead to something like this, a threw hull fuel tank vent fitting.
http://greatlakesskipper.com/produc...-thru-hull-polished-chrome-gas-tank-vent.html
My nephews is low by the water line and running in salt (or mabey ethenol) got plugged up, but will also give your a symptom of when you go to put fuel in the tank it will take ALONG time for the tank to accept the new gas. Took along time to fuel up.
Recap
1) Bad primer hose (ball)
2) Clogged tank vent
EDIT: Good thinking on the reversed primer DJ.
DamianJP
dew2
Try turning the hose around the bulb has arrows showing the flow
